Why my weather widget time not running at the same time in the phone clock?i am using note 8.
  • Start date Start date
A
Android Central Question
My time in the weather widget is not running at the right time and not the same in the phone time in my note 8...how can i fix this?kindly please help me to make this run at the right time same with the phone time...i try everything but it didnt work at all...anyone knows the solution?thanks
I would suspect that your weather widget is set to a location not in your time zone.
Look for a setting in the "Widget Settings" that says something like "Follow me" or "Use my Location" for "Time Zone" or "Location", like bbgpuser stated, that is more than likely your issue. The Widget is stuck on a fixed location when you want it to follow you wherever you travel - that way, it uses the phone's GPS to determine where it is and gives you the time, date and weather for that location!
sportzfyapp
