Why should my battery draining so darn fast?
TheGoodNamesAreGone
111
This is with brightness set to a low level, and power save mode enabled. I turn my mobile data off while here at home so that won't cut into the battery, but I'm still seeing significant drain even while I sleep, here are several screenshot of my battery usage
Perhaps forgetting to shut off chrome is part of it, but I still don't get why it's so precipitous in the rate in which in drops. I forgot what time exactly I went to sleep last night, but I know it was well before 2 am. So it certainly wasn't active use on my part doing it.
I do not know if this you have tried the following:
I have turned off notifications as my default setting. I only allow notifications for messaging apps that I use. In addition, I turn off all apps after I have used them. Before putting the S6 Edge in my pocket, I push the power button to lock the screen to prevent butt calls and inadvertently opening apps.
I can normally go through a day without recharging.
3 hours 35 min SOT while browsing, using apps is average. Nothing to worry about. I can even drain my S6 edge under 4 hours under heavy usage.
Posted with ❤Love❤
