Why wont my battery charge why im using my phone
  • Start date Start date
Welcome to Android Central! Which phone? Do you still see the lightning bolt inside of the battery icon in the status bar? If so, then the battery is still charging, but what you're doing on the phone is matching or outstripping the charging rate.
Are you plugged into a wall outlet or a USB port on a computer?
More info is needed. After you register and can reply, we need to know a few things.
Phone make and model? (Some are worse than others for this)
Do you still get the charging notification when this happens?
Is this a complete halt of charging, or is it just really, really slow?
Is this any time you use the phone, or do certain activities influence it more than others?
Are you feeling excessive heat when it happens? If so, where?
Bear in mind that we can't help you if you don't reply, in which case you must seek help elsewhere. I don't know of any better sites for such help than this, but let us know if you find one.
pcjordanellis
