Why won't my HTC M9 turn on (weird issue, help)?
  • Start date Start date
A
AC Question
My HTC M9 Will Not Turn On (weird issue, help)
I was using my phone and it got to 0% and it turned off. I plugged it in to a wall charger (HTC charger that came with phone). After checking on it 30 minutes later, I noticed there was no LED light on whatsoever that would indicate it was charging.
When I press the power button on, it will go to the normal boot up but turn off after it says HTC (white and green screen).
When I hold the vol down and power, I get a battery symbol, grey on the inside with a plug picture and a circle around it, underneath it says 0% and turns off again.
Anyone know what the issue is? Greatly appreciate the help
Re: My HTC M9 Will Not Turn On (weird issue, help)
What happens when you plug in the cable?
Unplug the charger from the wall and wait a few seconds, then plug it back in and then plug in the phone.
Ive had HTC chargers go dumb and not put out any voltage. Unplugging them fixes the issue.
Hold Power and volume up whenever this happens to softreset... It's equivalent to a battery pull.
Sent from my HTC One M9 using Tapatalk
I had this problem once before. Keep charging for a long time (I don't remember exactly how long) then press and hold the power button.
liliin
