Wi-fi problem?
Octaviannn
129
Since 2 days, my wifi icon on the notification bar became grey. Also the network icon became grey. I dont remember doing anything on my N4 except of changing the main Google play account. Any ideas?
Posted from my Nexus 4
So its constantly grey? What does it say at the bottom when you pull down your notification bar?
I dunno what ure meaning, but here are some screenshots.
Based on the screen shots you have displayed here....You don't have any kind of connection to you wifi or mobile connections.... As the previous poster stated gray means no connectivity blue is vice versa... I don't really know what your specific issue is as you have not clearly stated.
Your device seems to think that there is no internet connectivity. Try rebooting the device, toggling wifi and aeroplane mode
Grey bars means that it doesn't have connectivity to Google services - you won't get push Gmail updates, or calendar updates unless you manually refresh, etc. If it happens again, and a reboot or toggling airplane mode don't work, I believe going to Settings -> Apps -> swipe to All -> Google Services Framework and clearing data, followed by a reboot or toggling airplane mode should resolve the issue.
Bad news. I did this, because it happened again. Now the wifi is grey, AND the google play app says me: no connection.
Update: i cleared cache of google play. Now it works. Thanks! Hope it doesnt break again!
heritagevine08
