WI-FI problem
carter17
193
9
Any one having any problems with the WiFi I use my moto x as a hot spot around the house my 2013 nexus 7 has never had any problems. But the g pad will connect then disconnect, then connect then disconnect. Over and over I turn WiFi off then back on. I forget the network then reconnect. It will work for a bit then start going crazy again. Any ideas?
I use my LG G2 as a hotspot with my G Pad and haven't had any problems at all withe the wifi. Also no problems with home or work wifi.
Les Felix
