Widget problem on home screen
anabolix
8
I downloaded a couple of widgets one having to do with battery, wifi, bluetooth, and volume I believe...
Well none of them worked and I'm pretty sure I uninstalled all of them. However on the most right side of the home screen it still says Problem Loading Widget..
Doesn't seem to be causing a problem but it is just really annoying.
Any help?
thanks
well I found out on a different forum. Sorry mods you can delete this thread. On the other hand if someone has a similar problem, all you do is press and hold where it says problem loading widget and drop it in to the trash.
cambium
