WiFi and Bluetooth problem.
luckydwg
136
I am having a problem with the stereo Bluetooth connection cutting in and out only when WiFi is on. When I turn it off no problems. Anyone else having this problem?
yep ... WIFI is definitely the cause ... luckily i only need this while i'm in my truck, so i just have a wifi widget handy .... but hopefully it's only software related and can be fixed
Oh good I thought I had a bad phone. I will be putting the widgets to good use.
Sent from my PC36100 using Tapatalk
not sure why i couldn't find this the last time i checked the forums. i even mistakenly thought (and posted) that the update fixed the cutting in and out of the bluetooth. i can also confirm that when the wifi is on and you stream via bluetooth to a car stereo that the bluetooth will cut in and out. with it off everything is fine. any idea if this will be fixed?
Yep I have this problem too. I did some googling last week and my impression was that this is actually an Android bug rather than something specific to the Evo. Not positive on that though.
