wifi connectivity problems?
Anyone of my a500 stock ICS people have any problems with consistent WIFI connection problems ??
Can you describe the symptoms a bit better?
Not seeing anything here on our 500 or our 700, but something may ring a bell with more information.
Sent from my A700 using Tapatalk 2
At least in my case, when starting up from power off (not sleep) mode, wifi will be on but it will not be connected to our router. You have to go into settings and manually reconnect.
Is your router configured to use some form of security?
I've noticed mine won't always connect to unsecured routers even if it has connected to that particular router in the past.
Oh, and here's where I insert my standard question asking why you turn it off?
These things are designed to run 24/7.
I have same issue since ICS update.
I have a secured WiFi with saved connection.
All my other WiFi devices are fine so it is the ICS update causing my issue...
boone
