Wifi doesnt work!! Help!
austin.n
15
I am having major problems with my wifi! im not a tech idiot and i just cant connect to wifi, phone says there is a network i press connect and then it does nothing, any tips on how to fix this. o and i tried using the wifi buddy app and that didnt work either..
nevermind, my buddy figured out how to get it to work, you have to select to forget the network and then bring it back, if anyone has this problem try this out!
