WiFi fast charger problem
TurkXtreme
69
hello friends,
i have samsung wifi fast charge pad.
it works with cable connection from computer (not fast charging)
but when i connect it with plug so it doesnt work. no normal charging or no fast charging. no any action.
do you know whats the problem about?
thank you.
Bad adapter? Did you try plugging in the wireless pad to the adapter that came with your Note 8?
i didnt try it. i am at office and my original adapter is at home. i bought this adapter from the internet as original. i am not sure its original or not. but it works as fast charger when i connect to phone directly. i am confused.
Oh Ok. That's odd... If you unplug the cable from the pad and directly into your phone and it fast charges the phone then I would guess the adapter is ok. But you say the pad charges, albeit not fast, if the pad is plugged into your computer and using computer power.
I'd guess I'd still try the Note 8 adapter and if it didn't work then looks like bad pad. Maybe those pads have some power requirement higher than charging a phone alone that the adapters wont work but power from a PC works maybe due to higher power output? A guess. Good luck.
thanks for your reply. i will try with my other adapter when i go home. maybe the problem is because of the adapter as you say.
changan9175
