Wifi Help ???
Apr 24, 2011
17
i recently got my G2X and i am having trouble connecting to wifi, the signal strength is fair but when i connect it gets up to the point to where is says obtaining ip address then never connects and its really frustrating, is there anyway to change settings so maybe it will connect any info on this would be greatly appreciated thanks
I bought new G2X and when I got home it did the same thing yours did. After a call to TMobile tech support they had me go back the store for an exchange. The second one worked like a charm. You might wanna check the networks password you entered or do a factory rest and see what happens. Good Luck.
hincapie
