WiFi is stuck at 'turning on' NEED HELP!
bobboisdoin
4
I have had my Galaxy S4 since its came out and about 3 months ago, I noticed my wifi wasn't on anymore. so I went to the settings menu and and wifi option is shaded. When I go to the wi-fi options all it says is "turning on". Its been like this for 3 months now and it is a real pain. I took it in to an android repair shop and they could not figure out what was wrong with it. Its a pain because its using all my data and that is not cheap! I figured if I updated it, that would fix the problem but apparently it needs to be connected to wifi to do that. I tried updating through kies on my mac and it says it is unsupported. Im running out of options. I have looked this up on different forums and found no help. Pleeeease someone help me! Im losing my mind!
Update: Just did a factory reset on my phone and it did not help anything.
- - - Updated - - -
I already tried that B. Diddy. Thank you for your reply though
thank you for the reply but I tried that before I reset my phone and it didnt work. Even after reseting my phone Im still having the same problem
I wonder if there's a problem with the Wi-Fi radio or antenna itself.
