wifi issue help please
Jason Southon
help please
when connected to wifi it switches back to 4g then back to wifi every 10 sec or so
adaptive wifi is also switched off
is there something can do to fix this or is this a software issue
thanks
My son's Note 8 was having this issue and we tried everything including turning off Auto Switch, turning on and off Airplane mode and forgetting and re-adding wifi accesses. His was doing it no matter which (or who's) wifi he was on. He ended up doing a factory reset and the issue went away. I don't recommend doing factory resets for everything, but sometimes they can work wonders.
BigRedGonzo
There is an ''aggressive switch'' between data and WiFi, maybe that was on by mistake, I think you find it in developer options or somewhere in advanced settings
Psilocyanide
