- Sep 17, 2011
- 108
- 0
- 0
Is anyone else having an issue where the wifi shows it's connected but doesnt seem to work?
Sent from my SPH-D710 using Tapatalk
Try switching the WiFi off and back on and see if that helps your situation...
It will usually work if you turn it off and back on again.
You need change your security from whatever it is now to wep on your wifi ... That will fix the staying connected issues..
Most routers default to channel 6, which is particularly congested. Try changing your router to a different channel like 2 or 11.
