WiFi Issue
Marley
94
3
Please help, as I am slowly going insane...recently, I upgraded to ICS 4.0.4. After this update, I am unable to connect to my company's WiFi. They have 2 types of accounts I can login to:
1. A guest account that you connect to under WiFi and then you login using guest credentials in browser.
2. A WLAN account, secured with 802.1x, where you login with your corporate credentials.
I prefer to login using the guest account, as our corporate accounts are monitored. I can connect under WiFi and put in the guest credentials in the browser; however, it always hangs on the authentication page where it says I will be redirected in 10 seconds or less. If I login using the WLAN account, secured with 802.1x - everything works fine.
Is this an issue with my phone? This was not happening before the ICS update....
Maybe doing a 1 minute battery pull will help; it did fix a Bluetooth detect/pairing problem with my car's phone system.
