- Jun 21, 2012
- 39
- 0
- 0
I just bumped up from a Galaxy S3 to an LG G3. On my S3, I had Wifi Mouse Pro, an app I paid for some time ago and updated once or twice after first getting it. I finally got to a place where it works nearly perfectly (with only one critical, but manageable flaw). Since then, they released several newer versions, and for many of them, several reviewers complained that the upgrade killed certain things and also added malware/adware to the desktop server software that's required for it. So, I refused to upgrade the app. The last version I have on my S3 is 1.4.6 and although most of my apps were successfully transitioned when I set the G3 up, this app did not cross over, which is in a way, good, since, I believe when the phone does this, it gets the latest version of the app from the app store. The store says 'Purchased' for this app, but it's not yet installed.
I want to transfer the version I have to my G3, so I don't have to upgrade the server software or kill the functionality of the app itself. There's no apk visible when connected to a PC, which is probably because it shows as a protected app in some file/app browsers and transfer utility apps, so using ES File Exporer, for example, failed. How can I do this without rooting and for free (ideally)??
