• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
Wifi off and battery drain, how can it drain that much battery?
A
AC Question
Hey.
I just noticed that Wifi has used 19% of my battery the last 1 day and 18 hours (since last charge). It was in top 2 of battery drain with screen on 19% too. But, I never use wifi, so it's always turned off.
I have an Xperia e4g, and I'm pretty satisfied with the battery life. I'm just curious to how it can drain that much battery while turned off?
Cheers, Sune
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,079
12
38
Re: Wifi off and battery drain
Welcome.
It may be false reporting. Since upgrading to Marshmallow, my Nexus 5 stock battery usage stats have reported very high usage for Wifi, often far higher than that for Screen. GSam Battery Monitor, by contrast, reports that all is normal. Try using that app, or a similar one, on your device. If high Wifi usage is still indicated, get back to us.
