droidntn Well-known member Jul 4, 2010 1,341 88 48 Sep 22, 2017 #1 Which is better done our battery conservation?
Almeuit Moderator Team Leader Moderator Apr 17, 2012 32,273 23 38 Sep 22, 2017 #3 Re: Wifi or cell droidntn said: Which is better done our battery conservation? Click to expand... It truly depends on the strength of said signal. WiFi is usually better unless you have a good LTE connection. A good LTE connection is easy on the battery just like a good WiFi connection is.
chanchan05 Q&A Team Nov 22, 2014 8,519 1 0 Sep 22, 2017 #4 As previously stated, the one with better signal.
