WIFI problem on my one plus 3T
  • Start date Start date
A
Android Central Question
As I had updated my op 3t to the latest updates from one plus my wifi turns on automatically for sometime and then again gets turned off it's creating a lot of problem also I have turned off the wifi scanning in the settings and the location services. I don't know what's going on and it's creating a huge lot of problems.
There are a ton of problems with the OP Oreo update - so many that OP has pulled the OTA. Some users have reported that doing a full factory reset solves all (or most) of the issues - but for many that doesn't even work. You can roll back to the previous Nougat OS - or wait until OP fixes the Oreo release and re-issues it.
opegamani
