[Wifi problem]
crossfirehurricane
3
Hi, I have a Galaxy S7 and cannot connect to wi-fi at my favorite brew pub. My Samsung Tab E tablet has the same issue. Several others that have Samsung devices also have the same problem. My laptop, which is not a Samsung, has no problem. I called Verizon tech support but all they did was refer me to Samsung tech support. I called them and the Samsung gal had me reset my network settings, but to no avail. The error message when I try to log in says "Webpage not available," along with an IP address and a MAC address. The last line says it "could not be loaded because: net:ERR_UNSAFE_PORT"
Any ideas? Is there a fix or workaround for it or am I just S.O.L.? Thanx for any help.
Sent from my Commodore 64 running Windoze 95
Welcome to the forums. Are you using an adblocker like Adaway, Adguard or similar?
Welcome to Android Central! This is not unusual for public wi-fi -- sometimes the business in charge of the router doesn't have it set up correctly. I've seen this happen from time to time at my local Safeway supermarket. It doesn't have to affect every single device that tries to connect. I don't think there's much you can do about that besides asking the pub proprietor to do you a favor and try rebooting the router.:-\
aktivasipinbnimobile
