wifi problem
BR34KF4ST
499
after updating to lollipop,my wifi takes at least 15-30 seconds to connect to the wifi compared to kitkat which is instant in connecting anyone has solution to this problem?im on OE1 if that matters at any point
Apparently this is a known issue since lollipop update, I find lots of posts when I did a google search. One possible solution is to wipe the cache partition.
Did you take a look at your Wifi Settings on your Phone? Most of the time after updating to Lollipop, they are resetting the settings,
Take a look, set some things on and off, Sure you will find something..
Well i downgraded to kitkat and the wifi connection was fast again thanks you all for your help
Adekanmbi
