Wifi Speed Cap?
jpirog
Active member
Oct 11, 2011
29
I have a T-Mobile Samsung Galaxy S3, just rooted with stock on it and when doing a speed test I'm getting some weird results.
From Speedtest on my GS3:
From Speedtest on my computer:
I'd say it's a pretty significant difference. My computer is wired, I know that'll make some of a difference, but definitely not THAT much as shown in the images.
The most I've ever gotten from my phone is about 10mbit. Has anyone else seen similar issues?
I have seen the same type of results with this phone and my iPhones before this one. Numbers very similar to yours from the phone. My broadband on my home computer is wireless too and I just pulled numbers around 40 down and 6 up the other day. Very big difference indeed.
this is from my galaxy s2 connected to my home wireless service from AT&T
u-verse. I'm rooted running ice cream sandwich
Sent from my SGH-I777 using Tapatalk 2
Weird...I mean, I guess it doesn't matter THAT much..but it bothers me because I like to maximize the potential of my device if it can get more speed.
Is anyone with a T999 (T-Mobile S3) having this issue? I want to see if this fix helps anyone. Respond to this message if you are or not and I'll let you know what the fix was.
Found the solution, My S3 was in Powersave mode for WIFI, in order to disable this mode, enter into service mode (*#0011#), hit menu button, select wifi and disable the power save mode from the screen, your WIFI will restart and should run at full speed
If you do this, please do a speed test first then try the fix, then try a speed test again and post your results.
It is common for G speed to be around that number. My phone pull like 10-21 mbps. Even that are capable of going to 50 mbps . However their workable speed is up to 20mbps due to overhead. It common for computer to show different result because the ethernet wire is capable for going higher than that. Basically G speed is cap at about 23 mbps. My computer show 53 mbps. Woot Verizon FIOS. Basically it is working as intended
Sent from my SGH-T999 using Android Central Forums
Sprint galaxy s3 is fine.....
Richie Q
