WiFi Wireless Tether, fix to add WPA encrypt.
techgeek32#WN
384
43
I have tried every version of WiFi Wireless on the Google Dec site and none of them offer encryption for a rooted ET4G. Has anyone found a work around for this yet? I can only use it in adhoc mode with no security. The same app worked fine on my old EVO4g.
I have the same issue... Lostkernel...
Sent from my SPH-D710 using Tapatalk
I suggest running a custom ROM and then using the Sprint Hotspot. I'm running Starburst ROM. The hotspot hack can be installed alone also.
I assume the Starburst ROM allows you to turn on the Sprint hotspot manually and without being seen?
mitiku Berihe
