Can only use the sim card outside the United States. Verizon is CDMA. Global means Mexico or using in Europe
Sent from my ADR6300 using Tapatalk
AT&T and T-Mobile?
As for the other replies, my fault. I know the difference between GSM and CDMA. I just thought that the VZW Droid was global like the other 2 are (Droid 2 and Droid 3). I know there's the milestone but that's 300 compared to 150 so I assumed that the OG Droid was international as well. So what about the other 2 models (Droid 2 and Droid 3)? Would they be able to function on T-Mobile's network if they were unlocked since they have sim cards? The reason I'm so persistent is because my aunt has an unlocked VZW Bberry Tour that works for calling and texts, but because she doesn't have a data plan she can't use the internet so I've seen it work on one VZW phone. Just trying to see if it applies to all their international capable phones. So far, I'm only finding out that the Droid 3 unlocked works on AT&T's frequencies only
Yes but whether a device uses a SIM or not doesn't really mean much. iDen devices use SIM's. LTE devices use SIM's. The device has to support the proper network tech and bands. The device cannot have a subsidy/network lock. It's not just a matter of "SIM versus no SIM".I'm pretty sure GSM networks use SIM cards in all their phones, right?
The droid 2 and 3 are able to work for t-mobile and ATT,
Like stated before you wont get the 3 G speeds, but will be on 2G Speeds. The phone is not as easy to crack as most, but it wasn't terrible.
there is a patch on another website that you apply to the phone, it cracks the locks that Verizon placed to prevent the phone to work on other carriers. Once done, and you have unlocked the phone to accept other Sim cards, the phone works great. My Droid 3 is on T mobile right now, and have no problems.
