- Mar 22, 2011
- 3,232
- 96
- 48
It seems my batteries are deteriorating and they are not that old. Do you think it is because of fast charge?
I don't think it does. I've been using fast charge non stop since November and my battery performance has not changed at all.
I remember speaking to a Samsung tech support rep a month or so before the release of the S6. He was going on and on about the great S6 battery technology. I did not believe him and from what it sounds like, the battery is not that great.
I'm curious, what makes you think your battery is deteriorating?
Yeah, Timely.. It isn't as straight forward setting 3 or 4 different alarms, but it works, is free, no ads.Off topic but did you ever find an alarm app that will let you schedule particular days? If, not I found one this morning while looking for a new app.
I'll check it out. I just can't not imagine why Android or Samsung (not sure which one did this) took the ability away to set more than one alarm, 2 or more days in advance, without making it a repeating alarm.You might Digital Alarm Clock. There are ads or a ad free version for $1.47.
Oh I have a loud custom sound that will wake you up.. It will wake up the people 3 houses down too hahaWhat chased me from the stock alarm was the length of the alarm. I need a long song to play in order to keep me awake. The stock alarms used to play for at least 10 minutes. 30 seconds is not going to do it for me. I think you can set numerous alarms in advance. I am testing it now.
Oh no, I could sleep through an explosion Hahaha. I need something to jolt me awake. Once I was up all night at the ER with a friend. I came home and only had an hour to sleep. I slept through the alarm, but it woke most of the dead in my state lolLol, yes, I just don't want to wake up that way. I even use fade in so I am not shocked. I can wake up at a very low volume. I just need a long song to then keep me awake enough to actually get up.
