Will Google Nexus charger work with S4?
I would say yes. I charge my N7 with my Samsung GNex charger all the time. All the non apple devices use the same micro USB connectors. I use generic cables and wall chargers all the time between as all my devices with no problem.
Sent from my Nexus 7 using AC Forums mobile app
I think the OP is referring to wireless charging. ;)
Is the s4 completely stock? I know there is some sort of aftermarket wireless charging option for the s4 but I don't think it has qi charging built in.
Yes ... stock. I thought that the S4 had wireless charging built-in ...
Sent from my SPH-L720 using AC Forums mobile app
I have three Qi chargers, one that I got from Verizon, a Nokia, and a generic one that I got last week on dailysteals. All work fine with my nexus 7 2013 and my s4. As long as it all uses the Qi standard, you can mix and match as well.
For various reasons, I would recommend the Nokia above all others.
The s4 does have inductive charging built in, but you have to put the inductive battery cover on it.
The cover is $19, with the Samsung coupon.
Phones with removable batteries usually require a different battery door for Qi charging.
Not to my knowledge. shopandroid I believe sells the proper accessory but you could probably find it cheaper from somewhere else.
Lala
