i read a couple of reviews and they say its not for hackers, due to internal storage may be ,, please give your opinions as i am entirely new to this but i would love to hack and customize![]()
sorry if i feel dumb, what that actually meant, new to android sceneFastboot oem unlock.![]()
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
This is what make a Nexus great. Most other phones are designed to stop you from installing custom software, but with the Nexus there is actually a built in command to let you do so.
In case the OP might not have understood what this means, basically that's all you need to type to unlock and root this device. Therefore its the MOST hackable android phone out.It's the code you type into command prompt/terminal to unlock the bootloader. This has the effect of letting you, the end user, control what packages/images are on your device--signed or unsigned.
In case the OP might not have understood what this means, basically that's all you need to type to unlock and root this device. Therefore its the MOST hackable android phone out.![]()
It's got a locked bootloader? Now granted its not locked as in HTC locked or Motorola locked where the fastboot command is disabled, and it only takes a few seconds but why is a locked bootloader on a nexus device? My n7 was locked too. Annoying because if you decide to root after you get your stuff set up, it wipes it and you have to start over.
My captivate had no such locked bootloader and it was a carrier phone. What's the deal?
Sent from my HTC PH39100 using Tapatalk 2
but if you somehow mistype the command, wont it go in a bootloop and may be restart problems as no removable battery?This is what make a Nexus great. Most other phones are designed to stop you from installing custom software, but with the Nexus there is actually a built in command to let you do so.
I hope thats sarcasmbut if you somehow mistype the command, wont it go in a bootloop and may be restart problems as no removable battery?
actually, i really asked you a question..
