Will normal case, fit over verizon extended? Will seidio black active fit extended?
wheresrenaldo
Active member
Aug 17, 2010
34
Will the normal back case fit over the verizon extended battery? Will the extended back case fit under a seidio active case?
No then Yes.
The original battery cover won't fit on the extended battery.
Almost all cases will fit over the Droid X with extended battery. The biggest thing is if the case is soft and pliable. I don't have the Active but I do have the Limited edition Active X and that DOES fit over the extended battery.
If you get a case that is too rigid and won't fit right, then maybe you could just leave the battery door off the Droid X, then it will fit.
I think you should be fine, every case I have tried fits the extended battery even if the manufacture says it won't.
Reactions: wheresrenaldo
marksains61
