Will phone turn on if I don't have a battery and i have a question mark on the screen
  • Start date Start date
A
Android Central Question
Can I use the lgvs985 without a battery by just plugging it in
No. The volts go through the battery.
When you try to turn one on without the battery but have it plugged in, the screen will turn on to tell you a battery is needed. You're correct that a battery is needed, but it's a programming limit and not hardware unrelated. Finding a way to bypass that check may prove so difficult that it's not worth trying. There's also the risk the charging system can't keep up with with a power demand spike and shut the phone down anyway.
amaka
