Will USA charger work in 220v countries?
Aserar
13
Hello all..
I purchased a phone from the USA and when I came back home I started using my old charger. I'm wondering if the US charger would work in 220v countries?
On both chargers it says "input 100-240v 50-60hz" but the old one says 0.2A, and the new one says 0.3A. does this means that it would work fine with no problem?
Thanks in advance.
Yup, no issues at all. The only problem you'll find, most likely, are the prongs. Electrical outlets in the US are usually different than European ones, so you'll have to get an adapter, but most chargers these days are built to be used with both Voltage configurations. Only if you see one rated only for 100ish VAC input, then you can't use that in Europe or you'll fry it.
justinpoland05
