Will you stick with Touchwiz? Or will u use another Launcher?
smooth4lyfe
Trusted Member
Sep 16, 2012
5,534
I usually have always a Launcher, but now that the S6 has Themes and has debloated Touchwiz, I just may give Touchwiz a try without any launchers. Some of the themes looks pretty good.
Will you guys stick with Touchwiz this time around? Or will you still use another Launcher
When I can change icon themes, size and number of icons per column and row… overlap widgets, use multiple gestures to bring up apps and a hundred other things I can do with Apex or Nova, I suppose I will stick with Touchwiz.
I usually stick with the TW launcher for the first couple of weeks. After that, I switch between it and Nova.
Can you install different icon packs to TouchWiz's theme feature?
I'd love to get Moonshine icons but still keep it TouchWiz, yknow?
Sticking with TW since stock themes will be in the store one the dev tool is opened up next week.
Sticking with TouchWiz and maybe a new theme. Changes the look and icon packs, pretty much like a third party launcher.
Posted via My Samsung Galaxy S4 Handheld Device
I personally never buy a phone that I don't like the UI or launcher. My m8 after one year still is stock and no need for a different launcher.
But my S4 had Nova prime installed after about 6 months. For my new S6, I'll probably stick with Touchwiz for a while then it's Nova for sure. It just depends on how much we can change with the new themes and all.
I tend to want to change the look of my phones at about the 6 month mark.
Probably gonna stick with TW for a few weeks and then switch to the Google now launcher.
@kbv1 how's it look? Does it fit smoothly? Any issues?
Considering how much faster this version of Touchwiz is, I'll be using it the entire time. As times goes on, there'll be a Google Now theme that I'll most likely go with, but outside of swiping left for Google Now, the Touchwiz launcher is more than capable on its own.
I usually go with Nova, but I'll give TW and the new themes a run.
Posted via S5 or Turbo.
I'll give TW a try and probably end up with nova it the end, because of icon packs, speed and the ability to save your set up.
I'll probably give the new TW a try for a while but I use a lot of features in Nova.... So TW will have to really show me something
Agreed
Posted via the Android Central App on my Galaxy S5
theantithesis
