Windshield Mount for Skyrocket with Case
s3ntrax
45
Hello,
I?ve been searching and searching for the best Windshield mount for Skyrocket that would fit while the phone has a case on.
I have the Seido surface case (pretty thin, but its still a case) and I?ve been wondering what the best windshield holder is for it.
Any ideas? Please let me know, I really appreciate your help and input!!
Thanks!!
I've got the Casemate Pop, which is pretty close in size. I've been using a Slip Grip mount. Rock solid and high quality. Not cheap, but definitely worth the cost. Odd, right now it looks like all mounts appear under the heading of OB Defender. When I bought mine there was one for a generic hard case (that's the one you want), another for no case, and specific ones for using an OB.
Using Defender Case
Khalequzzaman
