[WIP] Nexus Rom porting method
igotsanevo4g
Retired Moderator
Jul 31, 2010
3,394
603
113
Hey OG's of androidcentral, i figured instead of XDA doing everythang we can whip something up. I have this booted up on my Evo, with a Couple bugs of course.
http://forum.xda-developers.com/showthread.php?t=614427
Yeah, its a nexus rom and it was a little tricky to get running, but it cant be that much different from Porting incredible to Evo roms, so i did the same procedure as if it was an incredible rom i was porting and i changed the stuff and booted up, much to my suprise it booted. BUT touch screen no workie.
So i tinkered around a little and a also flashed netarchys universal, sure enough she boots right up and the touch works fine.
The problems; NO sprint or carrier signal, i dont know what to switcha round from nexus's GSM to evo's CDMA, and ... yeah. Also bluetooh no workie (probly an easy fix)
WiFi and SD mount DO work. Edit, WiFi quit on me.. hangs at obtaining IP address.
Suprisingly, HDMI, 4G, and neither of the cameras work.
BUT, it seems stable, ive had no bootloops.
So. I figured us OG's on Androidcentral could catch some glory from the XDA boys for once and get this down, as of now ive searched high and low and there isnt a bonefied method to port em.
Community help/work/ideas are why i posted this, so if youd like to help out, PLEASE do. I'm no superman at this stuff haha.
Let's do dis shiz :D
___________
Downloads.
THIS IS FOR DEVELOPMENT ONLY.
It has glaring problems and im well aware, flash if you want. It wont bork anything, but its by no means ready for human consumption.
Alpha - http://www.megaupload.com/?d=7U76QMML
If you get graphical glitches like i was (Nova panel) then flash this
http://forum.xda-developers.com/showthread.php?t=719763
The 4.1.9.1. universal, less agressive.
Extras.
For some reason the keyboard disappeared so, yeah.
http://forum.xda-developers.com/showthread.php?t=744373
ADB install that and its fine. (Dont ask me what happened to the keyboard)
Reactions: Jerzyiroc
Hmmmmm
I need to Port a Rom so I cant figure this out... Im one of those people who have to be hands on...
Regardless im happy you got the rom booted... :cool:
Yeah it boots and wifi works kinda.
Imma get wifi and maybe cell reception fixed today.
Then post a download for willing people.
The Radio for the phone is the Radio for the phone. Doesn't matter which ROM you flash the radios are closed proprietary firmware so the same radios used to a sense ROM are the same radios used on a CM ROM are the same radios used for .... oh you get the point lol
You may need to set the access point name (APN) and also may want to ensure it's not disabled. You might have luck having someone pull an original unedited APN from an EVO and try using that.
Cheers and good luck.
U the man Kevin... :cool:
But I didnt Mean a Radio like a Flashable thing I knew all that :p
Xda doin' it again
They are coming up with this "FLASH-PATCH" Thing that will flash all the Evo system Files needed to port a Rom after you Flash an INC Rom or even maybe a Nexus Rom?
It doesn't work with nexus roms. I tried it and no touch screen, I had to flash netarchy universal over it.
But now I just have a cyanogen kernel cooked in.
Ahhh okay. I have no clue how or what to do to achieve that but its a start I guess.
I just got home, gonna dig in soon.
Ill jump in here,ill try and help out where i can.I don't have a evo to test things on but i can probably help with a lot of other things.
Igotsanevo4g-Whenever you get a chance to upload what you have shoot to me in a pm or email mrbeezy420@gmail.com Im more of a hands on person that has to have things in front of me.I will say you are probably goign to want to stay with a cyan kernel or build one from his sources.
Reactions: igotsanevo4g
Awesome man.
Let me package what I got up and sign it when ill upload it.
I've been getting some graphical glitches with cyanogens kernel, none with netarchy universal
Uploading as we speak, Ill just put the download on the first post so others can grab it if they want to also.
Use HTC kernel and modules for the EVO. Will probably fix your graphics glitch.
I have the modules in there already, and the stock HTC kernel doesnt boot :p
Only fix so far is to flash the netarchy universal, which i may just cook into the rom. It runs nicer than the cyanogen kernel or any others ive tried.
It'll all be for naught if i cant get these damn radios flipped on lol
Update: Beezy fixed the bluetooth :P
kelkongko0510
