Wiping battery stats in Alsop liberty with two batteries
deadlift425
Active member
Jul 19, 2010
31
Unable to clear the stats in recovery. Says I have 40% when the battery is fully charged! Any tips?
Sent from my DROIDX using Tapatalk
I recently had an issue in CyanogenMod 7 with my battery counter. I tried resetting in CW but it had no effect, much like you mentioned. I am in the process of testing, but someone suggest an app called "Battery Calibration". Search it in the market, and maybe it will work better than CW has.
In clock work when you click clear does it just flash quickly and not give you the option to say yes? If so soon as you hit the camera button hit the down volume key and it should work.
sent by CyanogenMod X
Chris34728
