Wireless Charger - Base for S4
mwatson2
Active member
Jun 28, 2013
39
I currently own an S4 with a wireless charging back and pad. If I get the wireless kit for the Note 3 would it also work on my S4 pad? I assume the size is different, but my S4 charges fine when placed at 90? from the required angle and sitting on the raised edges. If someone with an S4 charger could test this that would be useful!
Thanks
It should, the pad from my S4 works fine with my Nexus 7 which is significantly larger than the Note 3. Don't have a Note 3 to test with, though.
Just be sure to check the charging rate/voltage of the new wireless charger base. It should be the same. If it's a higher rate/voltage, then consider not using it just to be on the safe side.
noroldie
