Wireless Charger Galaxy Buds
heatherburks
121
Any one know what Watt wireless charger is needed for the Galaxy Buds? I've searched everywhere with no luck!
Any should be good. You can charge then from your phone and that is a fairly low charge, and that is up to 4.5 w.
I can charge them with Samsung's old non-fast charger that came out around the time of the Note 5, as well as with this year's charger duo pad. So yeah, anything should work.
Great thanks y'all just didn't want to get one too high and ruin them! Or too slow and be pointless haha
If you're worried about wattage, just keep an eye on it while you are using it. If it gets too warm, maybe a lower wattage is appropriate.
John20
