Wireless charger that works with a case?
bigcanoe
70
Hi,
I am looking for a recommendation for a $20 range, stand style, wireless fast charger that works through a case for my Note 8.
Thanks!
The correct question should be, what case will work a wireless charger? All wireless chargers work the same way, it's the case that you should research if it works with a wireless charge. Some are too thick and will not work with a wireless charger.
I didnt know that! I have a Spigen clear shell. Are there different wattages or amperages that I need to look for?
No, they're all the same (some do Quick Charge, some don't, but the distance over which they work is all thee same). The Spigen case isn't as thick as the Otterbox Defender, and I've used a cheap Qi charger through that for a few years.
jades
