- Nov 12, 2014
- 55
- 0
- 0
What's a good wireless charger to get? Meaning i m looking for somthing that doesn't take 3hours to charge my phone
any info would be nice thanks to anyone that replys
I use the Tylt Vu charger (TYLT • VU • Wireless Charger). They had a half-off promo for Thanksgiving weekend, so I bought two. Works great as a stand with the phone both upright and sideways.
There's a thread in the Nexus 6 accessories forum for some more options: http://forums.androidcentral.com/nexus-6-accessories/464076-google-nexus-6-wireless-charging.html
Qi charging is still not that good compared to plug in. It maybe convenience, but the heat generated from those chargers degrade the battery life even more than plugging it in. If the N6 had a removable battery, Qi charging would definitely be highly recommended IMO.with ALL wireless chargers your going to trade off speed of charge for convenience. There is a lot of power lost with the conversion of wireless charging. So if speed is needed skip wireless all together.
Not true about the one included with the Nexus. Unlike most 2.0 quick chargers, the moto turbo charger uses something called trickle charging. What that means is that there is a chip inside that detects levels and adjusts the voltage and amps accordingly. When the charge reaches 90%, volts and amps get lowered, which is why you see different amp and voltage values under the charger itself (For folks that own a Nissan Leaf, BMW i3, or Tesla with 440v capabilities, you know what I mean).Heat is the biggest culprit to reducing potential cycles/capacity of Lithium chemistry batteries, but chargers that run at higher voltage (like the included turbo charger, which can run considerably higher) also degrade battery life (source). If you are concerned about the battery performing as well as possible for as long as possible, you'd do best to use a 'normal' charger for 'overnight' charging or other times when speed of charge isn't a major concern, and using the OEM charger only when you really need a quick boost.
That being said, if you only plan on keeping the phone a year, you'd probably never notice a big difference either way, and only marginally if two, so should factor in the convenience of Qi/Turbo charging in your decision on how to charge.
Overcharging causes battery degradation.
