Wireless Charging and Phone Cases
Mizmelzy
Active member
Jun 2, 2014
27
I will be getting my Pixel 4XL on Wednesday. I also would like to quick charge my phone with a wireless charger. I am looking into phone cases. What type of case do I need to buy so it wirelessly charges. Does it matter? Or can I just by any case and it will charge regardless? I bought a cheap one just to start me off ,but if I don't have to buy a specific type of case to wirelessly charge my phone then I don't want to.
Thanks!
Mel
Thanks!
Mel
I've been using the pixel stand as my wireless charger, I have one in my office and one in my night stand since the pixel 3 xl last year and now the pixel 4 xl. I had 8 cases for my 3 xl and wireless charging worked with all of them. So far for the 4 xl I'm using one of Google's official fabric cases and wireless charging works and also have a Spigen clear case which wireless charging works as well.
I think based on my past experience most cases will be fine unless you purchase one of those dual layer cases like OtterBox then you might have a problem if they are too thick. I haven't encounter any cases so far that wireless charging did not work, but also I've never used really bulky or dual later cases.
This is the one I bought says hybrid but it's basically one piece. It had a Flexible TPE bumper + Solid PC back plate. So hopefully it will work.
Mel
Pixel Stand works with my Pixel 4 and Pixel 3 in Speck Presidio Grip Cases.
Mel
You should be fine with that case. Even with thick otter box cases you'll be fine. The only time you'll find inconsistencies is if you use a case with a metal plate in it for those magnetic car mounts.
Sounds good. I did not get a pixel stand wireless charger. I got one off of Amazon recommended by another Pixel 4 owner that works good. Will be nice not having to plug my phone in at night. Just sit it on the charger :)
Mel
Mel
This is a biggie for me too - enjoy!
dkpiper
