Wireless Charging Battery Cover
molinap1
64
7
I was looking at accessories for my wife's rezound and came across a wireless battery cover and charging pad. Haven't seen it mentioned and was wondering if anyone was thinking about trying it or has seen it in action.
Does anyone know if it makes the phone thicker (like the extended battery)?
It has been discussed before. It does make the phone thicker, not as thick as the extended battery though. You will need a wireless mat to go with it
Thanks. I'll search again. Didn't see it on my last search.
Hi All, I have the wireless charging cover and mat. Also xtended batt. and cover(not wireless). I have noticed with the wireless cover people say I fade in and out periodically (also with the stock cver), but never had that issue with the extended cover.
Just want to know if anyone else has had that issue?
noroldie
