Wireless charging notifications
extraclass
618
5
I purchased a wireless charging system for my S-4 and it works great as a charger. It is a base and a thin card that fits in the phone and uses the standard back. The card is thin and fit right in my S-4. When you place the phone on the charger pad it comes up with a screen that says something about charging wireless. It charges through my protective case and works through mu wife's Otter Box case!
The problem I am having it it keeps waking me up with continuous notifications that the battery is charged. The phone wakes up, screen comes ON and I get the notification beep and a screen telling me that the battery is charged and I need to disconnect the charger! It repeats this every few minutes!
When charging with the cable I only get 1 notification! That doesn't bother my sleep.
Anyone found a way to stop the repeat notifications?
I found an App that turns off all notifications during "Quiet Hours" but this stops all notifications and keeps the phone from ringing. The app is Do Not Disturb. There is a setting with the App that will let the phone ring if someone calls twice in 5 minutes.
I'm just guessing here, but I think it's built in by Samsung to make you remove the phone from the pad. Wireless charging generates more heat than cable charging so it makes sense to not leave the phone on the charger over night as you will damage the battery. Try to only charge until you get the notification. My humble opinion. If anything personally I'd try to find an app that stops the trickle charge when battery is full even if the phone is still on the charger, not an app that silences notification
repairphone12
