Wireless charging problem
May 28, 2014
3
I have a wireless qi charger from Linocell that I use with my Galaxy S5. It works well, except that the screen keeps lighting up intermittently, even though I'm not getting messages and the battery isn't full. I can't find any information about this anywhere...
It has happened to me before. For me, it was because the connection was not very good. Maybe try to reposition the phone
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3
It happens because when the battery reaches 100% the charger disconnects and reconnects when the battery drops to 99%. Unfortunately, it will keep doing this the whole time. What I do, since I use it at night, is turn down the screen brightness all the way down and turn down the notification volume as well. Hope this helps.
Thanks, I'll give it a try.
- - - Updated - - -
No, that's not it, because as I said it happens regardless of the battery level.
Did you ever find the problem for this? I'm having the same issue. It begins to charge then disconnects and reconnects ever few seconds or so. I'm gonna try and reset the qi receiver under the battery cover.
Check your power supply. I noticed that if I use a power supply less than 2mah I would get the connect disconnect problem. once I swapped out the lower power units the problem stopped.
CasperTGhst
