Wireless Charging Question
icnmayhem
295
Is there a difference, other than being official and a lot more expensive, between the samsung wireless back and the off brand qi chargers they sell on amazon? Just wondering, since it seems like the samsung one replaces the entire back and is thicker. If the both work equally well, I'd just as soon get the cheaper one.
thanks, i may go with the cheaper option then. i saw att has nokia chargers for $25, or $19 if you buy three. just need to find one of those chip thingies that goes under the battery door.
MidnightRaven9
