Wireless Charging Question
mhettrich
800
Just curious as to whether the wireless charging cover will work with any qi charger, or if it only works with the samsung charging pad?
you can use it with any pad, as long as they say qi. i got 3 nokia chargers off at&t website for $18 each. i also use one of those qi chips off amazon, instead of the samsung chargin back, i think it was $12 or so.
Amazon and eBay have qi receivers for the Note 3, around $12 work great. I have one in mine!
I've tried 2 receivers and none worked. Not sure why so I ended up with the wireless S-View case instead
edc
