Wireless charging question
Keith Wardlow
66
I have the Samsung Wireless charging pad, could I use the Fast Charging Adapter with it, or should I stick the the wall Adapter it came with? Would it make a difference in charging speed, or would the fast charging Adapter not work like its supposed with the the chargig pad? For some reason when I am plugging in my micro usb cable into my phone, it seems does not go in smoothly
Won't matter. It'll only use what it can and fast charge doesn't work with wireless charging. Just make sure you use at least a 2 amp charger.
Sent from my SM-G925V using Tapatalk
You can use the fast charger with your charging pad, but it won't charge your phone any faster than one that came with the charging pad. Right now Qi doesn't support quick charge.
There should no issue with it. The device will be fine and you will,probably have upgraded by the time it would have even been an issue. It makes little sense for Samsung to provide a rapid charger if it is going to damage your device.
I just use the wireless charging pad with the adapter it came with for regular charging, or just plug in the cable that came with the phone for quick charging.
04ijordan
