Wireless charging Question
Clouduss
9
Random Question came to me the other day after receiving my 6P and sitting down at my desk.
Out of habit, I sat at my desk and dropped my phone on my wireless charging pad to the left of my keyboard. I knew as I was doing it that it wouldn't charge, but I like having my phone sitting on a clean surface (especially in our honeymoon phase :-* ).
It made me wonder, is it bad for your phone/battery to be placed on a wireless charging pad when the phone does not have it enabled?
Rukbat
Retired Moderator
Feb 12, 2012
44,528
29
Other than the very slight heat radiated by the pad (which is probably no more than 2 or 3 degrees above room temperature), no. And that amount of heat would probably shorten the phone's life by less than a femtosecond. (If the pad doesn't indicate that the phone is charging, it's not drawing current from th pad, so it's the same as sitting on a slightly warm piece of plastic.)
efforting
4
I could be wrong but it was my fault understanding that there is a NFC chip in the charger that calls to the phone to activate the charging.
VidanLydin
