Wireless charging stand
the game 161
Banned
Oct 14, 2014
111
Arrived today
Nice
Very nice! I like the angle and that they got rid of the blinding ring of light. Kudos!
I have this stand as well and it definitely does not charge the phone as fast (not even close actually) as plugging it in to the fast wireless charger. I've tried with the case on and off. Have you had this problem too?
Will try it later haven't checked yet.
What kind of times are you getting from 0 to 100?
Fast Wireless charging is NOT the same as Fast Charging with a wired one. Fast Wireless is only faster than previous wireless chargers, but it's actually closer to a standard 2A wired charger.
Here read the "Faster Charging" Section
http://www.androidcentral.com/quick-look-samsung-fast-charge-qi-wireless-charging-pad
And here are some nifty graphics comparing charging speeds.
http://phandroid.com/2015/09/25/samsung-fast-wireless-charging-comparison/
Ok something is not right with mine then. This is from 50%-100%
And this is using the fast charge cord 50-100%
Are you using the wired Fast Charger plugged into the Fast Wireless charging? I have to ask, some people have been connecting it to a standard charger and the speed is noticeably slower.
Do you have the fast charge setting switched on? The accessories option. Go to apps, settings, scroll down to accessories, make sure that it's turned on. (Fast wireless charging). Hopefully it will start working for you. Good luck
I have the same problem and I have seen reviews of others having the issue, as well. I returned one thinking it was the charger that had the issue, since the wired fast charging is fast, but the new wireless works the same. I need to contact Samsung about it, but haven't gotten around to it yet. I have a thread in the S7 Edge parent forum from a few weeks ago about it.
Paid $75 on BestBuy on 3/27. Model: 60-3692-05-XP
Do you think it may not be compatible with the S7?
Bruins11 - I finally wrote to Samsung about it and apparently nobody else has yet, as they said they haven't heard of this problem yet. They told me to go to my carrier's local store and try charging another S7 Edge from them on my Wireless Charging Stand. I have no idea if Sprint will let me do that, but I guess I will try, since I don't know anyone else who has an S7/S7 Edge. This will rule out whether the problem is with the chargers (since this is my second because I exchanged the first one due to the charging issue) or my phone They also told me how to ship the Wireless Charging Stand to them for their people to test and check out. I think it would be worth your time to write to them, as well, since nobody else with this issue has.
I have it on my desk at work and love it. Haven't timed it but I would say it's about as fast as a standard 2.0 amp wired charger. Plenty fast for my needs. If I need a really fast charge, I unplug the cord from the wireless stand and directly into my phone.
