wireless charging with case.
natehartey12
217
Does anyone wireless charge with a case on? If so, is it slower charging than without a case?
Only problem I have with my case is the phone as to be perfectly centered on the charger to charge. Without a case I can set it down and walk away and it will charge no matter how it's sitting. Speed doesn't vary though.
That's a good question lol. I always wireless charge with the case on. I'm going to try it with it off.
Posted via my Galaxy Note 5
I wireless charge with a Spigen Neo Hybrid case and it charges just as fast with or without the case on.
I have a case on mine not very think but it's very protective, no problems with wireless charging
I have an Otterbox Defender on mine, and it charges just fine. I am using the regular Samsung wireless charger as well.
I use the Verizon wireless charger with an Otterbox Defender and it charges just fine.
Same here. My phone has to be perfectly centered.
I tried charging mine last night with my case on. I use the tylt vu. It worked flawlessly!
I use the seidio dilex case and wireless charge with no problems.
Via AT&T Note 5
I think it depends on the case and the charger.
With my thin case and my more protective case with the Samsung puck, it worked fine, minus the problems with the puck randomly stopping.
I bought a spigen charger and it didn't work with either case, tried out a tylt charger at best buy with the same results.
The choetech charger is fine with both cases as is the Samsung fast charger.
Samsung fast charger and verus case charging fine with plus / minus 1cm from center of charger
lorribarnes
