wireless charging without case
jpcsoccer
94
i would like to get wireless charging without the case.
the first i got required me to take the NFC sticker off the back of the case. I was very hesitant to do this.
now i find this sticker
Has anyone tried this? does it work? is it easy?
are there other options to try?
thanks
I literally just bought that sticker and installed it yesterday. Yes, it works and works well. I charged my phone completely last night on my Qi charger.
It took me 5 minutes to remove the old NFC sticker and install this one. I even got the contacts in the right spot on the first try. If you're scared, watch this video first.
thanks
Installed my a week ago. Works great although slower than quick charge
Why? YOu understand that the Qi stickers come with NFC, right? All you're doing is swapping out NFC only for NFC and Qi.
They're taking about the coil cover sticker. It's a cosmetic thing, you don't NEED it but some people, like my self, like it
Oh well, mine came with a new sticker to put over the coil sticker, so no need to save it.
I just ordered the "abc" sticker from Amazon Canada... Coming from China in a few weeks. I'll post here how well it works.
I had no luck with the sticker on my leather back, manufacturer even sent me a improved one, no luck. I went with a cheap flip and plastic after market back with it pre-installed with no problems.
Posted via a LG G4
Posted via a LG G4
Weird. You're sure the contact points were in the right place? There's really no guide, so it's easy to get them on wrong. Glad you found one that worked.
babainagBN
